UART HW control
RE: UART HW control
by wizdaniel ·
Hi Andreas Achilleos.
WizFi250 can support HW flow control via CTS and RTS pins. But I don’t know what is your problems. because of the lack of explanation.
RE: UART HW control
by soellicha ·
Thank you for your reply.
I mean that I have set both MCU and wizfi to operate with H/W control and when I connected the 2 devices they could “talk” even with CTS,RTS pins unconnected!
Is this possible?
RE: UART HW control
by wizdaniel ·
AS I said WizFi250 can support CTS, RTS pins. But it is not required to use it.
You can use a Simple UART(TX, RX, VCC,GND), not use CTS, RTS.
So, Communications between MCU and WizFi250 are possible even though CTS, RTS pins unconnected.
