Consecutive Bus operation
RE: Consecutive Bus operation
by lawrence WIZnet ·
Hello, barrey.
I do not use W5300, but i hope this is helpful for your wonder.
Before that, there is my question with your mention.
-It means you want to access two w5300 with a your 32-bits cpu(mpc5554)??
Then, here is an answer with below words.
W5300 supports burst mode, so you can read or write addr & data consecutively. But the point is CS and RD/WR status.
Offically, W5300 notice CS’ active low and RD/WR’ active low to read/write. If you do consecutively, you need to toggle RD/WR signal(with CS signal active low continuously) to make CS & RD/WR active low at the same time as the timing diagram in w5300 DS.
And I suggest the pulse high of RD’ duration is longer than tDATAh + tDATAhe.
Thank you,
Lawrence.
by barrey ·
Hi and thanks for your answers,
No, The external bus is 16 bits wide, and I have only 1 wiznet device wire. I mean that if, in the code, I read (or write) a 32bit data, since the external bus is only 16bits wide, the MPC will automatically proceed with 2 consecutive reads (or wirtes) (of course the MPC increment the address between the 2 access!).
In others words, the MPC is able to read (or write) 2 consecutive 16bits registers of the wiznet, in one single code operation, and put that 2 16bits register of the wiznet into one 32bits register of the MPC.
That’s
I wanted to know !
[quote]W5300 supports burst mode, so you can read or write addr & data consecutively. But the point is CS and RD/WR status.
Offically, W5300 notice CS’ active low and RD/WR’ active low to read/write. If you do consecutively, you need to toggle RD/WR signal(with CS signal active low continuously) to make CS & RD/WR active low at the same time as the timing diagram in w5300 DS.[/quote]
That not a problem, when the MPC proceed 2 consecutive access, the CS stay low durring the 2 access, and the RD/WR toggle between the 2 access.
That would be nice to have a confirmation on that point. For the read operation, I have a 15ns pulse on the RD signal, (for Write operation, I have 30ns on WR signal).
The question is : tDATAhe value ?
Since in my case the MR(RDH) is set to ‘0’ this mean that tDATAhe= 0ns ?
So in my case the minimum RD pulse would be tDATAh + tDATAhe = 7ns + 0ns = 7n ?
Could you confirm this point ?
Hello, barry
I am so late…
Yes you are right!
Only tDATAhe set after MR[RDH] set as ‘1’.
And the valid time will be 7ns if tDATAh is 7ns and no MR[RDH] set.
thank you
lawrence
