W5500 TCP - write to TX buffer before connection up
RE: W5500 TCP - write to TX buffer before connection up
by Coccoliso ·
The socket has to be connected.
You can not fill the TX buffer of a disconnected socket because you do not know in which location write … the two TX buffer pointers are updated only upon connection.
by billbgarland ·
Hi Coccoliso
Can I do this:
Open a TCP socket
Write message to FIFO and save TX_WR pointers
Wait for the connection to come active
Modify TX_RD and TX_WR pointers to point to message in FIFO
Issue a SEND command
The reason I want to do this is that my host has very little RAM and I want to save my message in the W5500 FIFO.
by Coccoliso ·
I do not remember the post but I’m pretty sure that the pointers contain 0 after reset but during the operations of opening of the socket containing two identical random values that are overwritten to the connection with the real value so I do not think that will work.
The buffers are used as random-access memory as long as the socket is connected.
