stm32f103xx spi + w5500 - Write successful but read returns 0
RE: stm32f103xx spi + w5500 - Write successful but read returns 0
You must receive 0x01,0x02,0x03 also during read. If you do not, then it means W5500 does not recognize the command.
Sounds like you write to wrong register page (e.g. to common register block).
RE: RE: stm32f103xx spi + w5500 - Write successful but read returns 0
by sr2018 ·
Dear Eugeny,
Thanks for your prompt response.
I am for some reason not getting 0x01,0x02,0x03 for read.
To read the version number, I am transmitting the following:
For the second problem regarding Socket 0:
I am doing the following to open TCP socket and then listen to it:
Socket open and listen are in the CR register 0x00, 0x01.
When I write I immediately pull the CS line up after the last byte is written and I receive 0x01,0x02,0x03.
However for read I let the CS line low so that I can read sequentially but do not receive any valid data, only Zeros.
Am I missing something?
Your help would be most appreciated.
Thanks,
SR
Please share scope shot of the communication between MCU and W5500 (in the best case having all 4 waveforms altogeter) for reads and writes.
