WIZ550WEB schematic TD+ -> TDN
RE: WIZ550WEB schematic TD+ -> TDN
HI.
What you use to RJ-45?
follow this URL → wizwiki.net/wiki/doku.php?id=pro … fschematic
This URL is W5500 Reference circuit
TD+ → TXP
TD- → TXN
RD+ → RXP
RD- → RXN
by PERLI ·
Thanks but I say about this:
wizwiki.net/wiki/lib/exe/fetch.p … 140925.pdf
Hi.
your question result is possible.
But, if you create new board see the W5500 Reference circuit.
I think. there is Auto MDI or MDI-X signal to internal of HUB and PC.
This feature is possible for signal matching.
Do you use to WIZ550WEB module?
And what you create to application?
by PERLI ·
Hi
–Do you use to WIZ550WEB module?
Yes, I use it as evaluation board
-And what you create to application?
I build instument with LAN connection
Thank you very mach
Hi
Thank you to your answer
any question?
more information refer to wizwiki.net site
by PERLI ·
But really
Why in Wiz550WEB (+) and(-) exchanged
error?
Hi
It is Not error
there is function to AutoMDI/MDI-X in PHY chip.
This function is Possible to TD+,- RD+,- signal matching.
But, you new create product by
TD+ → TXP
TD- → TXN
RD+ → RXP
RD- → RXN
please signal matching.
by PERLI ·
but W5500’s PHY can not support Auto-MDI/MDIX!!!
Hi.
It is possible to other side to Auto MDI/MDIX. (other side of Ethernet)
