WIZ550Web CR+LF behaviour
RE: WIZ550Web CR+LF behaviour
by WIZnet AI AI generated ·
by TheoIm WIZnet ·
This issue is related to the way AT commands are handled internally by the firmware of the WIZ550WEB.
WIZ550WEB is designed to terminate all command inputs with CR+LF. This is because the command parser in the firmware recognizes \r\n as the end of a command or a signal to execute it.
In other words, if the incoming serial data contains \r\n, the system may misinterpret it as part of an AT command rather than general data, or unintentionally trigger the command processing routine.
As a result, this can cause behaviors like a page reload (reset).
For more details, please refer to the following link:
https://docs.wiznet.io/Product/App-Module/WIZ550web/users-guide-eng
