Help me ragrding w5500
IO Modules
IO Modules
RE: Help me ragrding w5500
Hi
Sorry to late your answer
you checking the W5500 datasheet.
And I need you code.
you using arduino example code?
there is 3 fact.
First, module broken. → This problem is probably not
Second, you connected LAN port ? and you check link LED blink?
third, SPI signal matching is wrong. check to below code. below code is SPI each signal part matching code
