Fail flash upgrade
RE: Fail flash upgrade
by felix ·
the BOOT pin is labeled on the WIZ550WEB-EVB.
We recommend upgrading the firmware by using a TFTP server. In case this server is not available and you are not able to install such a server, you can still use the Flash loader of STmicro. Please refer to the instructions on wizwiki.net/wiki/doku.php?id=pro … b_download - also please take care to use the proper addresses for programming the APP and the BIN files.
Reset the device after flashing both files and open a serial console to the UART1. The module will ask for
You should respond with the letter S and the MAC address of your module, for example: S0008DC010203 as one string.
The module will then respond with the following header:
[code]Input MAC ? R
OK
WIZnet WIZ550WEB Revision 1.0
Embedded Web Server Module
Firmware Version 1.0.1
=======================================[/code]
Best regards,
Felix
by stragr ·
Dear Mr Felix,
We have uploaded the 2 bin , maybe succesfull, in 2 different addresses, as you described.
But, after the last reboot we terminal program that we use , it returnes only two “00”, “00”… Nothing else.
There is NO message “INPUT MAC?”
Now you say to enter the MAC address with an “S”. Where we can find the mac address. Is it written anywhere?
We didn’t keep it, and if it doesn’t ask MAC what shall we do?
Best regards
Stratos
by felix ·
If your upload was successful and at the right address, the module would be asking for the MAC address.
Make the board enter the BOOT mode by pressing the BOOT pin and while holding reset the board. It will automatically enter the BOOT mode and you will be able to use a stmflasher to flash the BOOT and the APP file one after another. After both files have been flashed, reset the board by pressing the RESET button or power cycling the operating voltage. In the meanwhile you should open a serial connection to the UART1 and there you should be able to see the input possibility for the MAC address. After entering the MAC address the module is ready to use again.
The MAC address is written on a sticker on the module itself. It starts with 00-08-DC.
Best regards,
Felix
by stragr ·
Finally i got lucky. The problem was on the power switch, i changed it and i got normal in “Program mode” and i put the firmware normal and success.
Thank you a lot.
