Problem in hardware
RE: Problem in hardware
by kavireloot ·
please help me…
by jeongsk ·
hi kavireloot
Your schematic is no problem. Artwork may be your problem.
Let me explain to me in detail the symptoms.
You should check.
by kavireloot ·
hi jeongsk
1.How i would Check 25MHz Clock oscillation ?
2.LINK LED first flashes then remains lit and then flashing, and the process repeats…
i used HANRUN HR911105a for Rj45…
and this is my board…change its from .pdf to .jpg…
۲۰۱۵۰۵۰۴_۱۱۴۳۳۰.pdf (2.24 MB)
by kavireloot ·
please help me…
thanks a lot…
Looking at your schematic and to connector datasheet I see that you may probably connected RJ-45 connector wrongly. You seem took pinout of the connector from sample W5100 board, but [url]https://dptechnics.com/datasheets/HR911105A.pdf[/url] shows different pin assignment. Please check.
by jeongsk ·
hi kavireloot
Your file does not open.
Explain your symptoms and test environments in more detail.
Scott.
by kavireloot ·
hi Eugeny
my schematic was wrong but i corrected it in PCB file…
thanks for reply…
i used from inductance ( 1mh) Instead of bead…is it influence in performance board??
this is my PCB file
s4.picofile.com/file/8187058734/ … cbDoc.html
by kavireloot ·
hi jeongsk
my TX-led and col led is off…
and Rx led is blinking with link led…
spd and fdx led is on…
by jeongsk ·
hi kavireloot.
You had to modify the circuit? Doeni the MCU and SPI communication?
bead is expected to have no problem.
Your PCB quality is likely not doing too low operation.
Ethernet signals are given more influence on the PCB because the high frequency.
And The VCC and GND is expected to be very unstable.
I says once again. Let explain to me in detail the symptoms.
scott.
by kavireloot ·
this is pic of my sck pin…
and my board
