W7100A programming protocol
RE: W7100A programming protocol
Hi Vitaly.
Which firmware version and hardware revision does you use?
Users can upload firmware to WIZ107SR module using configuration tool.
It should be noted that only application firmware parts can be uploaded using configuration tool. (!! does not included ‘Boot’ parts !!)
Available upload method are as follows:
(When the ‘boot’ part is already uploaded)
If you want to making your own configuration tool, please refer to the WIZ107SR programming protocol guide - ‘WIZ107/108SR S2E Programming Guide’
wiznet.co.kr/UpLoad_Files/Re … _V100E.pdf
