WIZ550S2E Modes
RE: WIZ550S2E Modes
by Ricky ·
Hi.
switching mode
WIZ550S2E operates in two mode that AT Command and Data.
To change from Data mode to the AT Command, you can send Triger Code(defalt(in HEX) 2B, 2B, 2B).
To change from the AT Command to Data mode, you can send AT Command(AT+MDATA).
nHWTRIG
nHWTRIG ON : enter the bootloader configuration status.
nHWTRIG OFF : enter the Application status.
RE: WIZ550S2E Modes
by gbaldoma ·
Ok Ricky, many thanks!
What is the default mode at boot up?
RE: WIZ550S2E Modes
by Viatcheslav ·
Hi, all
I tested WIZ550S2E in data mode with Packing Conditions option (Time). I input 1000 in this field but when I send 5 symbols through UART to WIZ550S2E I see in Wireshark 5 packets with minimal length = 60 bytes and only one byte in every packet. 1000 (ms) as I believe means 1 sec time. Is it Software error ?
RE: WIZ550S2E Modes
by Ricky ·
Hi~
i can’t understand your question correctly.
first, as you believe 1000 is 1 second.
and Packing Conditions time process
time-------------------------------serial--------------------------------------ethernet--------------------------------------------------------------------------
↓ your keyboard input [data 1] -----> WIZ550S2E[data 1] -------------------------------------> Some Server/Client
↓ your keyboard input [data 2] -----> WIZ550S2E[data 1, data 2] ---------------------------> Some Server/Client
↓ your keyboard input [data 3] -----> WIZ550S2E[data 1, data 2, data 3] ------------------> Some Server/Client
↓ your keyboard input [data 4] -----> WIZ550S2E[data 1, data 2, data 3, data 4] --------> Some Server/Client
↓ -------------------------------- if you don’t keyboard input, count the condition time value----------------------------------------------------------
↓ -----------------------------------------------------if condition time value over ------------------------------------------------------------------------------
↓ ------------------------------------------>WIZ550S2E --------------------------------------------> Some Server/Client[data 1, data 2, data 3, data 4]
[color=#BFFFBF] ↓ ------------------------------------------>WIZ550S2E[data 1, data 2, data 3, data 4] ---------> Some Server/Client[data 1, data 2, data 3, data 4][/color]
thanks.
