W5100 in server mode... host uP buffer overflow
RE: W5100 in server mode... host uP buffer overflow
by scowell ·
OK… no help… I’m guessing that in order to force TCP to break this data into 32K chunks I have to disconnect and reconnect for every block? As long as the socket’s open then data will pour into the buffer with no regard to the size of the Winsock send()? I’m reading the documentation for the W5300 and I now understand that when I send the RECV statement this is actually setting the receive window for the next TCP packet… so what I should do is only set the pointer to allow the window to complete the 32K on the next-to-last packet. Then I have to remember to put this space back in when the final packet comes in so the process can repeat. I’ll try this and repost later.
by scowell ·
Never mind… we’ve decided to go with a different solution.
