Analog input example
RE: Analog input example
Hi, I’m sorry for late reply.
The section that displays the ADC value is located at function replace_sys_env_value() in main.c.
If you do not have a problem with the source code, please check the configuration of web browsers. (e.g., IE. cache settings)
And please test again using chrome or other browsers.
Regards,
Eric.
