Problem at this stage "void reg_wizchip_spi_cbfunc"
RE: Problem at this stage "void reg_wizchip_spi_cbfunc"
by Christian ·
Dear Midnightcow,
I have checked the wizchip_conf.h file and all was and is still definded as you mention.
Any other think that can cause that problem?
Christian
by Christian ·
Dear Midnightcow,
you are right I am having a problem with the WIZCHIP structure, just working on it and
got a update of my compiler and had some new problems that are solved now.
This is how the structure is:
And here I am getting in the wizchip_conf.c file this error message: Assigning to non-lvalue WIZCHIP.id = WIZCHIP_ID,
Thx for the support
Christian
by Christian ·
Problem solved.
I change declaration of the “id” variable (wizchip_conf.h file) from 6 to 7:
uint8_t id[7]; ///< @b WIZCHIP ID such as @b 5100, @b 5200, @b 5500, and so on.
