Arduino and w5500
RE: Arduino and w5500
What did you mean unplugged??
Disconnection between W5500 and UNO?? or UNO and power cable?? or else??
Did you write and read other registers??
Did it have no problem??
by coffeecupnz ·
if the UNO is not running a sketch i would assume all pins are input by default and should not affect the hardware …(i’m not an arduino user so not sure, but this would be the case with a PIC) but even if your pins where outputs and driving the SPI pins i still don’t see how that would bring down your mac and ip address etc… anyway just to be sure, use a resistor and LED and confirm your UNO is neither sinking nor sourcing a current… specially confirm your uno is not sinking current… most of my classmates forget 0V is still an output!!
by suhwan ·
Dear coffeecupnz,
In your hardware (Arduino UNO + W5500EVB),
Arduino UNO could not access W5500 in W5500EVB.
Please, check SCS_N signal as below pictures.
Thanks,
by Phice ·
[quote=“hjjeon0608”]Hi,
Did it have no problem??[/quote]
For Unplugged I mean disconnected from the board, and also when UNO is not powered.
I compiled a blank sketch with SPI.h included, so the ports are set properly.
[quote]
but even if your pins where outputs and driving the SPI pins i still don’t see how that would bring down your mac and ip address etc… anyway just to be sure, use a resistor and LED and confirm your UNO is neither sinking nor sourcing a current… specially confirm your uno is not sinking current… most of my classmates forget 0V is still an output!![/quote]
I checked, it’s working well.
Which picture?
how can I interface an Arduino board then?
Thanks everybody,
I don’t understand your question yet.
How all the parameters are assigned correctly when SPI wire is not connected and not powered???
And did you check SPI data signal with oscilloscope??
