[SOLVED] wiz550io client fails to connect to http
RE: [SOLVED] wiz550io client fails to connect to http
by coffeecupnz ·
Thanks midnightcow I appreciate your reply
I’m not sure I understand though, if it were a port being re-used why would chance have it that it always fails when I attempt to connect to port 80?
I’m not attempting to open both ports on the same piece of code, rather, I compiled my code with port 21 hardcoded, then recompiled and cycled the power with port 80 hardcoded in. And always, it is port 80 that I fail to connect to…
by coffeecupnz ·
here’s my code, sorry i should have included earlier
void wiz550io_hit_server(void) {
switch(hit) {
case 0: // idle
break;
case 1:
spi_send_short(0x0010, 0x2C, 80); // dest PORT 80
spi_send_ip(0x000C, 0x2C, 101, 98, 9, 49); // dest ip
spi_send_ip(0x0001, 0x04, 192,168,1,5); // gateway
spi_send_ip(0x0005, 0x04, 255, 255, 255, 0); // mask
spi_send_short(0x0004, 0x2C, 13742);
spi_send_short(0x0012, 0x2C, 1024);
spi_send_char(0x0000, 0x2C, 0x01); // TCP mode
Server application could hold before port number although before connection is closed(e.g. windows).
If that, Server application doesn’t accept re-connection with same port(combination of source and destination port number) number.
If you want to connect with same destination port number, I recommend to change source port number and open.
by coffeecupnz ·
ok, i see that’s what midnightcow was saying as well, thanks
i’ll test that out and upload my results
by coffeecupnz ·
still no luck,
i’ve modified the code to loop through port numbers and left it running all night.
here’s the new code
#define SP 49292
switch(hit) {
case 0: // idle
break;
case 1:
spi_send_ip(0x000C, 0x2C, 10,1,1,1); // dest ip
spi_send_ip(0x0001, 0x04, 10, 1, 1, 1); // gateway // was 192.168.1.5
spi_send_short(0x0004, 0x2C, my_port);
please if there’s nothing wrong with the code is it a problem with my setup? I have the module connected to my laptop’s ethernet port, i enabled ‘share my internet connection’ on the laptop, on the module the gateway ip is my laptop’s ip address. that wasn’t working so i tried connecting the module directly to the router ‘10.1.1.1’ and try to access the routers config page on port 80…
please any sugestions welcome
by coffeecupnz ·
Cheers for that
I have since re-written the code and tidied up some bits, but I’ll check at home tonight that I didn’t carry that mistake across!
Thanks
