Serial command for setting DHCP range
RE: Serial command for setting DHCP range
by kaizen ·
Hi
I think that you have to change your device IP using command.
Currently, Your Device IP might be 192.168.16.1 or 192.168.16.254. So It’s DHCP pool range can use 192.168.16.11 ~ 192.168.16.50.
You can’t use 192.168.xxx.xxx ~ 192.168.xxx.xxx range excepted 192.168.16.xxx address.
So I recommand that you will change your device IP using <WI192.168.0.xxx> if you want use range of IP ( 192.168.0.xxx ~ 192.168.0.xxx )
by SomeUser ·
Sorry for my absence but unfortunately that doesn’t seem to be the problem
<S192.168.0.1>
<S255.255.255.0>
<S192.168.0.1>
<S192.168.16.10_192.168.16.102>
<WH192.168.0.10_192.168.0.100><2>
You can see that my IP address is already set correctly.
by SomeUser ·
Actually a little more information:
(In case it matters this is using the DEV kit)
<S192.168.0.1>
<WH192.168.16.10_192.168.16.102>
<WH192.168.16.10_192.168.16.100>
<WH192.168.0.2_192.168.0.3><2>
<WH192.168.0.20_192.168.0.30><2>
<WH192.168.16.14_192.168.16.104>
<WH192.168.0.14_192.168.0.104><2>
So it seems like this command only works if I am not changing the subnet. Is this a bug?
Paul
by ssekim ·
Hello Paul
Please try it again as below.
<GO0> <WT0_192.168.1.254_255.255.255.0_192.168.1.1_0.0.0.0> <WI192.168.10.254> <WS255.255.255.0> <WH192.168.10.101_192.168.10.200>With these command scenario, it worked well.
by SomeUser ·
I tried again and I’m afraid it still doesn’t work:
<WI192.168.10.254>
<WS255.255.255.0>
<WH192.168.10.101_192.168.10.200><2>
You can see that the WH command returns <2>.
<Sv1.1.28>
Is my version old?
Paul
by ssekim ·
Hello
[code]
[/code]<WT0_192.168.1.254_255.255.255.0_192.168.1.1_0.0.0.0>
<WI192.168.10.254>
<WS255.255.255.0>
by ssekim ·
Hello
About this issue, I asked to s/w engineer of WizFi630, and he recommend .
Because there can be another dhcp servers in AP-mode-network, so there are some limitation with .
How about using the instead of as below?
<GO1> <WT0_192.168.1.254_255.255.255.0_192.168.1.1_0.0.0.0> <WI192.168.11.254> <WS255.255.255.0> <WH192.168.11.101_192.168.11.200>RE: Serial command for setting DHCP range
by SomeUser ·
I can confirm that I can set the DHCP start IP address on the LAN ports using Gateway mode.
But I must use AP-MODE.
I want to construct a network with multiple WizFi630 modules.
Each module has 2 IP ports bridged together.
One module has a static IP address and is set to DHCP mode (the router)
All the other modules should be set to DHCP client mode.
I must be able to control the DHCP range to my range (192.168.0.xxx).
Is there anyway that I can do this through the serial interface in AP-MODE only (given that the WH command doesn’t work in AP mode).
Thanks,
Paul
by ssekim ·
But, in my guess, is almost same like except WAN interface.
You can just set WizFi630 as and set with dummy static IP.
Then, I think that WizFi630 can run like .
To implement what you want in AP mode, WizFi630-S/W needs to be modified.
