Does the W5500 require a hardware reset?
RE: Does the W5500 require a hardware reset?
by peterjak ·
That’s okay, but page 44 of the datasheet PHY configuration infers that this is the case when it says
“When W5500 is reset by POR or RSTn PIN,” . So maybe that needs to be changed to “When W5500 is reset by RSTn PIN”.
Also in the same section “After POR or RSTn reset,” needs to be fixed.
So that line can’t be floated, is that right? Yet section 5.3 states
“RPU – Pull-up Resistor – SCSn, RSTn, PMODE[2:0] – 62 – 77 – 112 Kohm”
