Question about activity led
RE: Question about activity led
by alexpescaru ·
UDP data is processed OK. TCP data is processed OK. The whole system is working perfectly.
I am sending UDP packets of 230 bytes, at 1 second interval, to a true/routable IP (195.225.x.x type of address).
The UDP packets are reaching the destination OK, without loss. So the logic/processing is OK.
But when the UDP packet leaves the W5500, there is no activity/pulse on the act led.
Also, on the same system, I have a small web server.
When the web requests are arriving and responded, the act is flashing.
So, for TCP packets, the led is OK. But not for UDP.
Does it matter the size of the packet? Again, the UDP packets are 230 bytes in length.
Thanks,
Alex
I think the connection has problem ACT pin to LED or LED has problem.
Check this.
by alexpescaru ·
In both my previous posts I’ve said that the TCP packets will turn the led on, but the UDP packets will not.
So the led is OK and so its connection.
I’ve investigated further and found out the following.
When an UDP packet is received, the led is blinking.
But when sending UDP packets, the led is not blinking.
So the problem is only when sending UDP packets.
Otherwise, the led is functioning OK, as it supposed to do.
