Technical question about the WIZ105SR / WIZ107SR
RE: Technical question about the WIZ105SR / WIZ107SR
by jameskim ·
Below link has brief information of all our serial to ethernet products.
http://www.wiznet.io/product/serial-to-ethernet/
You can see that both have 3.3V TTL Interface for serial.
An important thing is that we have another part for RS232 in case of WIZ107SR.
If you want WIZ105SR, then you can order with part name, WIZ105SR.
But in case of WIZ107SR, you should place the order with the part name, WIZ107SR-TTL.
Please don’t use WIZ107SR-RS232 on your order sheet.
BR,
James
Hi joena,
Both of the products you mentioned support 3.3V TTL signals.
In particular, WIZ107SR offers two models: TTL version and RS-232 version. There is a slight difference in hardware between the two products, so please check the ordering info when ordering the product.(WIZ107SR-TTL / WIZ107SR-RS232).
RE: RE: Technical question about the WIZ105SR / WIZ107SR
by sudheer kumar ·
hi sir
how to post message in forum
by joena ·
Thank you both for your answers
Kind regards, Jeroen
