Preview of W5500IoT in WIZ820io footprint + opt CPU
IO Modules
IO Modules
RE: Preview of W5500IoT in WIZ820io footprint + opt CPU
by peterjak ·
[quote=“midnightcow”]Hi, Peterjak.
Can you show me the photo of W5500Iot module ?
Thank you.[/quote]
This has been renamed IoT5500 so as not to be confused with WIZnet modules.
[url]Dropbox - Error
by peterjak ·
Latest product shot of both the IoT5500 module plus the optional +P8 network/file server with microSD header (or 16MB SPI Flash). The +P8 is normally sandwiched on top of the IoT5500 pcb to form a complete stand-alone HTTP/FTP server plus telnet and SMTP. So the W5500 can either be interfaced normally via SPI to the host CPU or the host CPU can interface serially to the +P8 network/file server to offload this overhead. The +P8 can even perform datalogging at the same time.
Interactive session
[size=85][code]Tachyon> ifconfig
************ NETWORK STATUS ************
HARDWARE: CE1432 P8M using WIZnet W5500
LINK UP
CHIP VER 0004
SRC IP 192.168.016.150.
MASK 255.255.255.000.
GATEWAY 192.168.016.001.
MAC 02.FF.4F.39.66.FC.
*** SOCKETS ***
#0 00:00:00 MODE= CLSD PORT# TXRW= . .RXRW= . .RXSZ= .IR=00 ST=00 closed
#1 00:00:00 MODE= TCP PORT# 21 53534 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN
#2 00:00:00 MODE= TCP PORT# 57634 TXRW=4B55.4B55.RXRW= . .RXSZ= .IR=13 ST=00 closed
#3 00:00:00 MODE= TCP PORT#10001 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN
#4 00:00:00 MODE= TCP PORT# 80 49904 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN
#5 00:00:00 MODE= TCP PORT# 911 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN
#6 00:00:00 MODE= CLSD PORT# TXRW= . .RXRW= . .RXSZ= .IR=00 ST=00 closed
#7 00:00:00 MODE= CLSD PORT# TXRW= . .RXRW= . .RXSZ= .IR=00 ST=00 closed
ok
Tachyon> ls
IoT5500
WORDS .DCT FIRMWARE.ROM WORDS2 .DCT W5200 .FTH EASYNET .FTH
EASYFILE.FTH SDCARD .FTH CE1372 .FTH EXTEND .FTH PREVIOUS.ROM
SITE0001.LOG HELP .TXT MENU .TXT WELCOME .TEL WELCOME .FTP
DEBUG .ROM POPCORN .WAV P8X32A .PDF HOME .HTM IMAGE3 .
FRED .PNG CE1372 .PDF FSRSCH .PNG FSRPCB .PNG IMAGE .
HTTP404 .HTM IMAGE2 . IMAGE1 . LOGON .HTM TACHYON .HTM
SITE0008.LOG SITE0007.LOG SITE0006.LOG SITE0005.LOG SITE0004.LOG
IOT5500 .JPG DRAGON1 .JPG ok
ok
Tachyon>
#1 00:00:00 MODE= TCP PORT# 21 53545 TXRW=A380.A380.RXRW= . .RXSZ= .IR=00 ST=17 ESTABLISHED 192.168.016.002.
220 WELCOME TO THE TACHYON WIZNET FTP SESSION!
[/code][/size]
by bangbh ·
Hi, peterjak.
I like your logo on the PCB.
In my case, I like to write the name of the girl group idol on the PCB.
