Migrating from WIZ820IO to WIZ850IO
RE: Migrating from WIZ820IO to WIZ850IO
Hi~
@erdemsimsek
I’m so sorry about getting back to you so late.
WIZ850io is hardware compatible with WIZ820io. WIZ820io users, to migrate to WIZ850io, need to modify the Firmware.
Because of the SPI frame of WIZ850io is different from WIZ820io.
thanks,
BR
by Francisco Fonseca ·
Hi. I have an issue about the process of migration firmware.
To successfully program the new firmware into the WIZ850io, what is needed? Do you have any dedicated program for this? Also, do you have any guidelines on how to do this change?
Regards.
