How to set password on 107SR?
RE: How to set password on 107SR?
Hi Grogster,
The WIZ107SR connection passwords must be entered separately without other characters like CR / LF (Carriage return, Line feed) in terminal.
I tested input the connection password using TeraTerm, I was found CR(0x0d) in the end of password string. (in wireshark packet captures) so, if you input the password to WIZ107SR TCP server using TeraTerm, the WIZ107SR recognized as invalid character. (e.g. ‘PASS’ => ‘PASS(CR)’)
if the WIZ107SR connection password option enabled and the input string is invalid password, the WIZ107SR terminates the connection. And the problem of the teraterm shutdown, please check(disable) the ‘Auto window close’ option in TeraTerm: TCP/IP setup.
I recommend that you use a another terminal program.
Regards,
Eric.
by Grogster ·
Hello - thank you for your reply. I will investigate. Can you recommend a suitable terminal program?
I recommend the ‘Hercules SETUP utility’ program.
Please refer to the next download link:
hw-group.com/products/hercules/index_en.html
Regards,
Eric.
