SOLVED - W3150A+ does not execute commands in Sn_CR
RE: SOLVED - W3150A+ does not execute commands in Sn_CR
by Daniel ·
Our module has almost the same schematic as the NM7010B+, well Layout is quite bigger (like Arduino shields).
Clock works fine, both PHY and Wiznet
I don’t have any signls on MII neither TXC/RCX nor any DATA (measured with Osci)
Didn’t chek link signal, but could it relenant for the “hang” siutation?
by miaooaim ·
if you don’t have the RX and TX clock on MII port, the command in Sn_CR will not be executed.
Check why the PHY don’t generate the clock.
Regards
G.
by Daniel ·
Thanks for the hint, it gave me the right direction for further investigations^^
My PHY has to be initialized by different MDIO write commands to a bunch of different registers (and first of all a software reset command, didn’t consider this^^). After this, I could measure a clock at the TCX/RXC pin and my commands in Sn_CR were executed.
Problem solved!
Thanks you very much!
