[SOLVED] Problem compiling RP2040-HAT-C examples
RE: [SOLVED] Problem compiling RP2040-HAT-C examples
by Fulvietto ·
I’ve found this discussion that give me the info I need:
https://forums.raspberrypi.com/viewtopic.php?t=350982
The problem I’ve understood is that you need the windows sdk too in order to compile the tools elf2uf2 and pioasm.
Following the thread linked above I’ve downloaded a precompiled version od the tools from here: https://sourceforge.net/projects/rpi-pico-utils/files/v1.3.0/ and saved them into the pico sdk directory:
C:\Program Files\Raspberry Pi\Pico SDK v1.5.1\picotool
Then I’ve added to the file C:\Users\fulvi\Documents\Pico-v1.5.1\RP2040-HAT-C\CMakeLists.txt the following lines (just before the pico_sdk_init() line:
the full file is:
This solved the problem and currently i’m able to compile wiznet’s examples
In the next days i’ll try to run them.
RE: RE: [SOLVED] Problem compiling RP2040-HAT-C examples
by Matthew ·
Thank you so much for the great information.
by eta-sys ·
Thank you Fulvietto for saving 3 days of my life! Professional presentation and comprehensive solution!
With best wishes:
Svetlin, eta-sys
