W5300 Receive problem
RE: W5300 Receive problem
by hiteshmandaliya ·
ThANK YOU,
But it is no where mentioned that when we set align bit= 1, it will not process any odd number bytes received.
In the datasheet the example of receiving 5 bytes is shown which takes no of byte info from Packet data itself.
I am using my own written code to acces various registers of W5300 and not the 8 bit driver provided by wiznet as my controller does not have external bus inteface so i use GPIO to acces the Wiznet bus.
Thank you , i will again look in to the wiznet driver for which you have sent a link.
Hitesh
