How to send data by muticast?
RE: How to send data by muticast?
by imeumimeum ·
I solved the problem,thanks.
by smashing ·
how you solved the problem.
I use this code:
u8 MutiCastIp={234,6,6,7};
u16 MutiCastPort=3000;
u8 MutiCastStr[1024];
I first creat socket as follow:
socket(3, Sn_MR_UDP, MutiCastPort, Sn_MR_MULTI);
and then send the data:
len =sendto(3, (uint8_t *)MutiCastStr, 536, MutiCastIp, MutiCastPort);
there is no error of sending len = 536,
but I can not receive any data on PC
Regards,
Smashing
Hi, smashing
I think you should check PC side.
Or router could block broad cast packet.
