MACRAW Application Note?
RE: MACRAW Application Note?
by irinakim ·
Hi Zick
We publish the PPPoE application on the wiki site in April 2014.
In this application note, we described the structure of PPPoE protocol implemented by MACRAW mode firmware.
You can download the application note & source code from [url]http://wizwiki.net/wiki/doku.php?id=products:w5500:application:pppoe[/url]
thanks
EK
by suhwan ·
Dear Zick,
As you know, MACRAW can handle the Ethernet frame.
|-- data length (2byte) --|-- DATA packet (with data length) --|
*Pseudo code for MACRAW mode
(ref. code: wizwiki.net/wiki/lib/exe/fetch.p … legacy.zip / socket.c)
Thanks,
by Zick ·
Dear ekkim and suhwan,
thanks a lot!
It’s nice to get good answers so early in the morning
(UTC+2 here…)
by vitech ·
I’m dealing with MACRAW mode and have some difficulties with filtration of incomig packets. I set up MFEN in Sn_MR according to datasheet
[quote]If user wants to implement Hybrid TCP/IP stack, it is
recommended that this bit is set as „1‟ for reducing host overhead to
process the all received packets.[/quote]
but where to I must write info about MAC addresses to be passed? haven’t found in dosc… neither datashit, not app note
by Zick ·
@vitech,
check out the SHAR register in datasheet page 33.
by vitech ·
Hello Zick,
All I see about SHAR register is it configures the source hardware address. Could you explain a little bit more, what I should write there when I want to enter multicast group and when I want to receive all multicast packets. By now I don’t get any meaning of this reg in MACRAW mode
by Zick ·
@vitech,
I didn’t try that myself so everything below is how I interpret the datasheet.
Then you’ll only get packets sent to 00:11:22:33:44:55 and FF:FF:FF:FF:FF:FF (broadcast).
by vitech ·
Some strange stuff continues to happen.
Initializing socket in MACRAW mode like that:
setSHAR(enaddr); setSn_MR(MACRAW_SOCK, Sn_MR_MULTI | Sn_MR_MACRAW); setSn_CR(MACRAW_SOCK,Sn_CR_OPEN); while(getSn_CR(MACRAW_SOCK)); while(getSn_SR(MACRAW_SOCK) == SOCK_CLOSED);MAC-address in SHAR non-zero. But, suddenly I receive all packets in networks, even with destination addresses that non-multicast and not mine (checked with wireshark).
How can I receive only broadcast packets (FF:FF:FF:FF:FF:FF) and packets with my MAC in SHAR?
upd: Fighting this problem for a week, still receiving all packets in network by the MACRAW socket without any filtration. Tried all flags in Sn_MR. so is that normal that there is no filtering of incoming packets??
upd2: was wrong, all works fine, was confused by ipv6 multicast addresses.
