W7200 MCU is always down
RE: W7200 MCU is always down
by alick3721 ·
What is un-registered ISR and Hardfault ISR?
[quote=“midnightcow”]Hi,
I wonder what is your problem? Do You hope led-toggle by using the internal timer TIM3 ? Am I right?
If W7200 be always down, your source code have a some problem.
Check the warning message in complier & analyze the log to be printed out on running code.
In my experience, It maybe halted in un-registered(default) ISR routine as Hardfalut ISR.
Thank you.[/quote]
