How can I configure the WIZ107SR via the serial port
RE: How can I configure the WIZ107SR via the serial port
by rhill ·
I seem to have solved this issue… I simply changed the default trigger code from “01 02 03” to “2b 2b 2b” (+++) and it seems to work correctly. It enters the serial configuration mode as expected and I can manipulate the configuration values as desired. I haven’t tried changing the trigger code further since this works for me.
