Troubles with 10 Bytes by sending every 10 miliseconds
RE: Troubles with 10 Bytes by sending every 10 miliseconds
by THendriks2 ·
Thanks for you’re reply.
At the endresult I need to send 3500 bytes every millisecond, so thats 3.5MBps.
When SSR is Established, I do the next steps:
next I check S0_IR1(SENDOK). If the bit become to ‘1’ I clear the bit. If the socket is closed before SENDOK become to ‘1’ or I cleared SendOk, I return for checking the SSR.
Need I, and is it posible to, get open the connection for sending these 3.5MBps or is there another solution?
by THendriks2 ·
I have fix it. I used a slow TCPserver in Delphi, that was the problem. Now I’m using a faster way to receive the data. Thanks for you’re help.
