How to stop connection after ATA command
RE: How to stop connection after ATA command
by kaizen ·
Hi
Thank you for your advice and there is my answer.
If your WizFi210 is data mode, you have to switch command mode using “+++” command and then enter “AT+NCLOSE=CID” command in order to disconnect with TCP server.
If your WizFi210 is command mode, you can use “AT+NCLOSE=CID” command without “+++” command.
