How Do I Get DNS IP Address Using Serial Commands
RE: How Do I Get DNS IP Address Using Serial Commands
by kaizen ·
Hi
I send e-mail attached modified firmware to you.
In this firmware, If you use command, You can see DNS server of your DSL router.
Please check your e-mail and test about this issue using this firmware.
by jkellar ·
Hi Kaizen,
Yes, I did get your email with attachment. I’ll give it a try and let you know how it works. Thank you!!!
by jkellar ·
Kaizen,
Firmware update worked out nicely and the command functions perfectly. Thanks!
