WizFi210 Resets, Freezes
RE: WizFi210 Resets, Freezes
by kaizen ·
Hi
If possible, Could you upgrade firmware to 1.1.1.0?
If this problem occur in latest firmware again, I will report it to our test team.
by bgrieve ·
Firmware 1.1.1.0 behaves the same as 1.1.0.5.
We receive “APP Reset-Wlan Except” occasionally,
as well as “APP Reset-APP SW Reset”.
One or the other and WizFi is dead.
by kaizen ·
Hi
For testing your issue and finding solution, We need full log of which you used.
Could you let me know which command is used ?
by bgrieve ·
Complete Log of the Crash and Freeze problem:
[UnExpected Warm Boot(Possibly Low Battery)]
[Error] or [Low Battery]!
Tx:ATC0
[OK]
Tx:AT
[OK]
Tx:AT+RESET
[ERROR: INVALID INPUT]
Tx:AT+XRESET
Tx:ATE0
[OK]
Tx:AT+NDHCP=0
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751475003
[OK]
Tx:AT+WD
[OK]
Tx:AT+WM=0
[OK]
Tx:ATC0
[OK]
Tx:AT+XEHT=2,1,0,3
[OK]
Tx:AT+XDUM=0
[OK]
Tx:AT+NMAC=?
40:d8:55:01:03:3a
[OK]
Tx:AT+NMAC2=?
40:d8:55:01:03:3a
[OK]
Tx:ATI0
WIZnet
[OK]
Tx:ATI1
GS1011
[OK]
Tx:ATI2
WizFi210
1.1.1.0(W)
[OK]
Tx:ATV1
[OK]
Tx:AT+PSPOLLINTRL=1
[OK]
Tx:AT+BATTLVLSET=2000,1,1800
[OK]
Tx:AT+BCHKSTRT=1
[OK]
Tx:AT+BATTVALGET
Battery Value:2.179 V
[OK]
Tx:AT+WS
BSSID SSID Channel Type RSSI Security
20:c9:d0:20:98:01, SSalinasWAP03 , 01, INFRA , -38 , WPA2-PERSONAL
20:c9:d0:1e:d6:51, SSalinasWAP01 , 01, INFRA , -38 , WPA2-PERSONAL
20:c9:d0:a1:40:4a, SSalinasWAP02 , 06, INFRA , -84 , WPA2-PERSONAL
c8:d7:19:43:cf:e7, SSalinasWAP04 , 11, INFRA , -20 , WPA2-PERSONAL
No.Of AP Found:4
[OK]
Tx:AT+WRSSI=?
0
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751477435
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751477460
[OK]
Tx:AT+WA=SSalinasWAP04
IP SubNet Gateway
192.168.1.254: 255.255.255.0: 192.168.1.1
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751480353
[OK]
Tx:AT&Y0
[OK]
Tx:AT&W0
[OK]
Tx:AT+NSTAT=?
MAC=40:d8:55:01:03:3a
WSTATE=CONNECTED MODE=AP
BSSID=c8:d7:19:43:cf:e7 SSID=“SSalinasWAP04” CHANNEL=11 SECURITY=WPA2-PERSONAL RSSI=-21
IP addr=192.168.1.254 SubNet=255.255.255.0 Gateway=192.168.1.1 DNS1=0.0.0.0 DNS2=0.0.0.0
RxCount=5 TxCount=54
[OK]
Tx:AT+CID=?
No valid Cids
[OK]
Tx:AT+WRSSI=?
-21
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751480585
[OK]
Tx:AT+NDHCP=1
IP SubNet Gateway
192.168.6.24: 255.255.255.0: 192.168.6.1
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751483860
[OK]
DHCP Time(Sec)=3.275
Tx:AT&Y0
[OK]
Tx:AT&W0
[OK]
Tx:AT+NSTAT=?
BSSID=c8:d7:19:43:cf:e7 SSID=“SSalinasWAP04” CHANNEL=11 SECURITY=WPA2-PERSONAL RSSI=-19
IP addr=192.168.6.24 SubNet=255.255.255.0 Gateway=192.168.6.1 DNS1=192.168.6.1 DNS2=0.0.0.0
RxCount=15 TxCount=110
[OK]
Tx:AT+CID=?
No valid Cids
[OK]
Tx:AT+WRSSI=?
-20
[OK]
Tx:AT+NSUDP=10004
[CONNECT 0]
[OK]
Tx:AT+CID=?
CID TYPE MODE LOCAL PORT REMOTE PORT REMOTE IP
0 UDP SERVER 10004 0 0. 0. 0. 0
[OK]
Tx:AT+NSTCP=40404
[CONNECT 1]
[OK]
Tx:AT+CID=?
1 TCP SERVER 40404 0 0. 0. 0. 0
[OK]
Tx:AT+NSTCP=30998
[CONNECT 2]
[OK]
Tx:AT+CID=?
2 TCP SERVER 30998 0 0. 0. 0. 0
[OK]
Tx:AT+CID=?
[OK]
Tx:AT+CID=?
[OK]
Tx:{Esc}U0255.255.255.255:10004:runt{Esc}E
Rx:[CONNECT 2 3 192.168.6.15 59535]
Tx:AT+CID=?
3 TCP CLIENT 30998 59535 192.168. 6. 15
[OK]
Rx:[DISCONNECT 3]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59536]
Tx:AT+CID=?
Rx:{Esc}S3GET /axis-cgi/io/input.cgi?checkactive=1,2,3,4,5,6,7,8 HTTP/1.1
Host: 192.168.6.24
Connection: Keep-Alive
{Esc}ECID TYPE MODE LOCAL PORT REMOTE PORT REMOTE IP
3 TCP CLIENT 30998 59536 192.168. 6. 15
[OK]
Tx:{Esc}S3HTTP/1.0 200 OK
Content-Type: text/plain
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59537]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59537 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59538]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59538 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59539]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59539 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59540]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59540 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59541]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59541 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59542]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59542 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59543]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59543 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59544]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59544 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59545]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59545 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59546]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59546 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59547]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59547 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59548]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59548 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59549]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59549 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59550]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59550 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59551]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59551 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59552]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59552 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59553]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59553 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59554]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59554 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59555]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59555 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59556]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59556 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59557]
Tx:AT+CID=?
Rx:APP Reset-Wlan Except
by kaizen ·
Hi
I did send reference to your e-mail for solving this problem.
Please check your e-mail.
by TakaoShimazu ·
Dear Support
Did this fix the problem?
I am also troubled by the nearly problem.
Please tell me.
Thanks
by ssekim ·
Hello
I just attached WizFi210 1.2.0.6 enterprise f/w version.
Please try it with this version.
