TCP windowfull condition
IO Modules
IO Modules
RE: TCP windowfull condition
by irinakim ·
Hi~~^_^
I recommend the method of using the No delay Ack.
As far as I know, If you only use send operation, W5500 don’t transmit the data until timeout operation occur.
If you set up the Sn_MR(No delay Ack bit enable),you can see faster speed than previous.
And how do you transmit 2Kbyte at once? As far as I know, TCP segments maxsize is 1460byte.
thanks,
