Communicating with the W5500io
RE: Communicating with the W5500io
by xyj19911129 ·
Hello, jdcowpland,
I met the same problem as you did. (using SPI to set gateway, ip, mac. etc)
I checked that the data format is right, (2 bytes offset address, 1 byte control code and then data) but I can not receive the response of W5500, the MISO pin is always 1 (according to the pull-up resisitance).
Have you solved your problem, and would you like to share your experience?
Thanks!
by jsavage ·
I am intrigued by the diagram. What tool did you use for that?
James
