Wiz830mj and UDP
IO Modules
IO Modules
RE: Wiz830mj and UDP
by Sergey ·
I use short packets with different lengths (1-40 bytes). When I use port 5000 wireshark forms a message “Malformed packet, Exception occured” and recognized protocol as YAMI, not UDP. I’ve tried port 5001 and wireshark didn’t find any problems and recognized protocol as UDP, but in both cases wiz830 gives me wrong data (all values are wrong). In wireshark data block of the packet is completely the same as I transmit from PC.
When I send one packet from PC it’s processed more or less correctly (except wrong data block), but after the second packet everything is wrong: source IP, port number, packet size, so I have to restart host processor’s programme.
I analyzed TCP packets with wireshark and found out that port 5000 is recognized as a port for “GSM over IP” and error message is given out, but data is transmitted correctly anyway.
by Sergey ·
mtyper=0x00ff; tmsr0=0x08; rmsr0=0x08. I work with 16 bits bus, so I used following commands :
IOWR(W5300,0x0020,0x0800) and IOWR(W5300,0x0028,0x0800). In case of TCP this works normally and data is always transmitted and received correctly. I tried 0x0808 values for tmsr01 and rmsr01 and UDP receiving process went on NORMALLY (data was correct). What do I do wrong? Anyway, thank you very much for the progress I’ve made.
