How to test the timeout condition iin wiz5100
RE: How to test the timeout condition iin wiz5100
by jbkim ·
Your test procedure is correct.
If you remove the Ethernet cable at the PC side, AX1 can’t connect the W5100 and show “Connect Fail”.
At the W5100 side, you need to check the Keep alive packet is sent or not.
If it’s sent correctly, W5100 should have TIMEOUT interrupt.
