W7100A boot problem
RE: W7100A boot problem
Hi, setime.
Bootloader doesn’t matter with code flash and data memory.
So, that W7100A works fine is correct. So I think there are other problems.
I want to know you use EVB or your own board and if you have another W7100, test same procedure and confirm ISP works fine.
Best regards.
by setime ·
Hi, hjjeon0608. Thank for reply.
Sorry, I didn’t mention that W7100A is mounted on the WIZ107SR module, i use it to implement own application.
Now I am working with another WIZ107SR module and its successful programming as before. But a broken module at the same time does not respond to attempts to establish a connection via COM port.
Regards, setime
Hi, setime.
I tested 107SR with your procedure.
But I don’t have seen problem like yours.
So, I recommend to request RMA.
Best regards.
