Assigning port no to ethernet module 812MJ's socket
IO Modules
IO Modules
RE: Assigning port no to ethernet module 812MJ's socket
by jbkim ·
Any port number can be assigned to the socket.
Do you use TCP server?
To debug this problem, you’d better use the Wireshark([url]http://www.wireshark.org/[/url])) and see what happen when you connect to the board.
by prashantkumar ·
I am getting RST signal in the wireshark when i use 502 port . what does it mean ? why it is not giving SYN flag .
by jbkim ·
RST means there is no socket having 502 port.
I think you need to check the port number is correct when you open the socket.
by prashantkumar ·
Hi ,
I tested wheather my socket gets assigned with other port no or not . ! and i found that any port no greater than 255 doesn’t get connected while port no <= 255 gets connected . I am using AX1 software from wiznets website , is there any limitation in this s/w or reason is something else ?
by jbkim ·
AX1 support any port number (~65535).
As the port number is 2 byte and you need to define it as Integer(2 byte) in your code.
