IP Filtering Usage
RE: IP Filtering Usage
Hi, anoopbabu.
Your procedure is correct but you don’t need to set destination IP and destination MAC as zero.
Because when connection established, it is changed automatically. Just close.
And UDP has no connection. After open, just send data and receive data. So you need to parse target IP when received packet and then drop packet.
Best regards.
by anoopbabu ·
Thank you very much for the inputs
