WizFi 360 - BSSID Roaming
RE: WizFi 360 - BSSID Roaming
by WIZnet AI AI generated ·
by maxrate ·
The WIZnet AI bot replied and this answers my question. I wonder if engineering has any plans to implement roaming. The AI suggestion about building my own (Signal Strength Monitoring) is a little tricky in transparent mode (at least I'd believe it to be).
RE: RE: WizFi 360 - BSSID Roaming
by Aimee0 WIZnet ·
We currently do not have plans to implement roaming functionality. However, we will review whether it can be incorporated in the future.
The
AT+CWLAPcommand returns a list of available APs.The
AT+CWLAPOPTcommand configures theAT+CWLAPresults to be sorted by RSSI.We recommend periodically using these commands to check the RSSI and connect to the AP with the highest RSSI.
