Using Two Chips Simultaneously
RE: Using Two Chips Simultaneously
by WIZnet AI AI generated ·
by TheoIm WIZnet ·
There is an STM32 example that demonstrates how to use two W5100S chips with a single MCU. You can refer to the maker site link for detailed implementation.
1 MCU, 2 WIZnet Chips: Dual SPI Networking on STM32
The key difference between the W5100S and W5500 is the number of available sockets, which must be considered in your implementation. The setup itself isn't complex. You can control each chip individually using a dedicated Chip Select (CS) pin, which allows you to operate both chips using a single shared set of functions instead of separate ones.
However, you must account for global variables that are socket-number dependent. For example, in
iolibrary/Ethernet/socket.c, you'll find definitions like:iolibrary/Ethernet/socket.c.These variables operate independently per socket, either bit-wise or as arrays. Therefore, you must ensure that they are allocated to cover the total number of sockets used across all connected chips.
For instance, when using two W5500 chips, you'll have 16 total sockets, so these variables need to be expanded accordingly. The example code already reflects this, so you can use it as a reference during implementation.
