Advertise W5500-EVB-Pico as network gateway using ARP (GARP?)
RE: Advertise W5500-EVB-Pico as network gateway using ARP (GARP?)
ARP/GARP is datalink layer, to get its functionality you must switch socket 0 into MACRAW mode. You seem to use UDP mode.
RE: RE: Advertise W5500-EVB-Pico as network gateway using ARP (GARP?)
by scooter ·
Right! Thank you for the reply, I’m using the default UDP mode, I guess I’ll have to rewrite this whole code and start opening sockets directly using Sn_MR, right? Or would I be able to set the socket like so below, and still use the code I already have?
Look into the libraries you use, hopefully there’re calls for MACRAW mode, or universal calls (eg. data I/O) which can be reused for MACRAW mode.
Is Sn_MR 8-bit?
by scooter ·
I’ll have to look deeper into the libraries then, thank you, I can’t test with the board until tomorrow, so I’ll revert back here then, in the meantime, here’s the Sn_MR register in the datasheet, it’s 8-bit, no?
Yes, then it is not clear for me how you can
write 16-bit value into 8-bit register unless there’s some hidden logic in this function
by scooter ·
Heh, great catch, still a lot for me to learn, thank you, absolute mistake by me!
I’ll update on progress in around 14 hours!
by scooter ·
So I managed to make progress, however I’m not managing to get packets sent out, it seems to always fail. I basically always get “failed to send”. Using the RP2040 Ethernet/ Ethernet2 library, it seems like I am setting the correct modes and registers through this code, I’d definitely appreciate some more guidance if possible
by scooter ·
Solved this by using a different Library
