Regarding AT+CIPBUFSTATUS Response
RE: Regarding AT+CIPBUFSTATUS Response
Hi @Padmini
I will check the segment ID issue.
And the TCP buffer size(TCP send buffer size) is set to 15,360.
Please refer to it.
Unless you have a compelling reason to use v1.0.7.5, please use the latest version.
The latest version is v1.1.2.0.
Older versions are difficult to support.
RE: RE: Regarding AT+CIPBUFSTATUS Response
by Padmini ·
Hi Austin,
We did see incorrect password issue with 1.1.1.7 version, Please check the below link for more details.
we need to change the SSID based on our requirement, so started using 1.0.7.5 where we are able to change the password and able to reconnect, which is not working with 1.1.1.7.
is this issue fixed in 1.1.2.0 ??
Thanks,
Padmini
Hi @Padmini
I answered the link below.
