MQTT SSL security
RE: MQTT SSL security
Hello @haricane00
To connect MQTT with SSL/TLS, set to ‘1’ in ‘AT+MQTTCON=<enable>,<broker IP>,<broker port>’.
However, it does not support entering certificates used when connecting to MQTT using ‘AT+MQTTCON’.
If you want to enter certificates, you can implement that part on the application and use it.
This is an example of implementing and using certificate-related applications.
Please refer to the example above.
