IP setup - Ping
RE: IP setup - Ping
Read written register values back to prove the correct values.
RE: RE: IP setup - Ping
by JRP ·
I am able to read all the configured values correctly. Having the following:
I try sending a ping with the device connected to my router as well as directly to my PC (both regular and crosover ethernet cable) without success. When connecting it to my PC, I made sure my PC had the “Gateway IP” per configuration in the W5500.
RE: IP setup - Ping
I would start with the following:
