Does MAC RAW mode skip the TCP/IP Stack?
RE: Does MAC RAW mode skip the TCP/IP Stack?
The chips are designed especially for hardware acceleration of the sockets. MACRAW mode, IMHO, exist if you want to perform something very advanced sockets can not do. Under normal architecture you use sockets in UDP or TCP mode.
Using chip in MACRAW mode will shift burden of the L3/L4 onto the driving device → it will have to read overhead and process it. It is by design slower, and how much slower depends on the SPI speed, driving device speed and algorithm/software used. Another issue here: you must remove received packets from chip’s RX buffer as quick as possible because if buffer overflows, further packets will be lost (discarded).
RE: RE: Does MAC RAW mode skip the TCP/IP Stack?
by Darius Botha ·
Thank you for your insight and answer - it is highly appreciated.
