W6100 start
RE: W6100 start
by Matthew ·
Hello.
WIZnet does not provide examples using the mcu. It would be good if you refer to the example below.
This is basic IPv4 DHCP
io6Library/Internet/DHCP4 at master · Wiznet/io6Library · GitHub
This is basic IPv6 DHCP
io6Library/Internet/DHCP6 at master · Wiznet/io6Library · GitHub
io6Library is the integrated library for dual TCP/IP statck contorller such as W6100.
You can run this code on your existing project.
