W6100 IPCONF is set by other device's ARP Probe
RE: W6100 IPCONF is set by other device's ARP Probe
Post contents of the packets being exchanged on the network - either binary or as a Wireshark pictures.
RE: RE: W6100 IPCONF is set by other device's ARP Probe
by tom3 ·
The image is a wireshark capture with two devices and a DHCP server.
The firmware is designed to send a DHCP Decline when IPCONF is set.
In the image, the TargetDevice is sending a DHCP Decline due to the IPCONF being set by the OtherDevice issuing an ARPProbe.
The desired behavior is to send a DHCP Decline only when an ARPProbe with an IP address equal to the W6100’s own IP address is received.
Thanks,
Should it send ARP response saying that IP address is occupied? Sending DHCP decline, at least as on the picture you provided, is broken process, because DHCP ACK was already sent and received in previous packet, and DHCP process has completed.
When in this packet exchange you have IPCONF bit set? In the packet 11 - someone else (12:00:07) asking if anyone on the network is having 192.168.2.206? What is your (W6100) IP address at the time when packet 11 is received?
by tom3 ·
Thank you for your reply.
For the DHCP sequence, we check for IP address conflicts by sending ARPProbes according to Sections 3.1 clause 5 of RFC2131.
In addition, according to section 2.1.1 of RFC5227, we check for ARP Probe or ARPResponse reception from other devices for 1 second after sending ARPProbe.
If there is no reception for 1 second, the probe is repeated three times in total, and if there is no reception, it is determined that there is no conflict.
I will explain the packet of the image.
In packets 1 through 4, W6100 (12:00:06) is leased an IP address of 192.168.2.204 from the DHCP server.
In packets 5-6, the W6100 just sent an ARPProbe twice to see if anyone on the network has 192.168.2.204.
The other device (12:00:07) gets IP address 192.168.2.206 in packets 7-10.
In packets 11 and 13-14, 12:00:07 is asking if someone on the network has 192.168.2.206.
The W6100 sets the IPCONF bit when it receives packet 11.
Thanks,
Sounds really strange. The next step would be - as soon as you get this interrupt from conflicting IP addresses (and before doing anything else), perform dump of all the common and all the socket registers and post here. Let’s see what regs have at the time of event.
by tom3 ·
Thank you for your help.
The first thing I want to know is the conditions under which the IPCONF bit is set. It doesn’t seem to be written in the datasheet.
All ARP Probe packets have a Sender IP address field of 0.0.0.0, so both packets sent by the W6100 (12:00:07) and received from other devices (12:00:06) will be 0.0.0.0. .
The IP address you want to search for is indicated in the Target IP Address field.
If IPCONF is set only by matching the Sender IP address field of the packet sent by the W6100 and received by the W6100, IPCONF will be set even if the target IP address fields are different.
In section 2.1.1 of RFC5227 it says:
“In addition, if during this period the host receives any ARP Probe where the packet’s ‘target IP address’ is the address being probed for, and the packet’s ‘sender hardware address’ is not the hardware address of any of the host’s interfaces, then the host SHOULD similarly treat this as an address conflict and signal an error to the configuring agent as above.”
Therefore, once again, when detecting conflicts with ARPProbe, it is necessary to determine if the Target IP address matches and the Sender MAC address does not match for received ARP packets.
If the IPCONF bit do not meet this condition, it seems necessary to check in firmware using a register that can obtain the value of each field of the received ARP packet.
thanks,
by tom3 ·
Sorry. There was a typo.
*W6100(12:00:07) → (12:00:06)
*Other device(12:00:06) → (12:00:07)
You can edit your earlier posts.
Manual states “IPCONF: 1 : IPv4 Address Conflict occurred”.
If you do not provide data for consideration, no one will be able to help. First of all we must prove that your W6100 is in proper state when “issue” happens. For this I asked for register dump.
by tom3 ·
Thank you for your advice.
I would like to know how the W6100 chip determines when an IPv4 address conflict occurs.
I got a dump of the registers after IPCONF was 1 as below.
–W6100 Dump common Registers.
CIDR =0x6100
VER =0x4661
SYSR =0xE1
SYCR1 =0x80
TCNTR =0x52C9
IR =0x04
SIR =0x10
SLIR =0x00
IMR =0x02
SIMR =0x00
SLIMR =0x00
SLPSR =0x00
SLCR =0x00
PHYSR =0x05
PHYRAR =0x00
PHYDOR =0x0000
PHYACR =0x00
PHYDIVR=0x01
PHYCR1 =0x40
NET4MR =0x00
NET6MR =0x00
NETMR =0x02
NETMR2 =0x00
PTMR =0x28
PMNR =0x00
PHAR =0x000000000000
PSIDR =0x0000
PMRUR =0xFFFF
SHAR =0x000000120006
GAR =0x00000000
SUBR =0x00000000
SIPR =0x00000000
LLAR =0xFE80000000000000040000FFFE120006
GUAR =0x20000000000000000000000000000000
SUB6R =0x00000000000000000000000000000000
GA6R =0x00000000000000000000000000000000
SLDIP6R=0x000000000000000000000000C0A802C9
SLDIPR =0xC0A802C9
SLDHAR =0x000000000000
PINGIDR =0x6100
PINGSEQR=0x0000
UIPR =0x00000000
UPORTR =0x0000
UIP6R =0x00000000000000000000000000000000
UPORT6R=0x0000
INTPTMR=0x0000
PLR =0x00
PFR =0x00
VLTR =0x00000000
PLTR =0x00000000
PAR =0x00000000000000000000000000000000
ICMP6BLKR=0x00
RTR =0x07D0
RCR =0x07
SLRTR =0x2710
SLRCR =0x02
SLHOPR =0x80
–W6100 Dump Socket 0 Registers–
Sn_MR =0x00
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x00
Sn_IMR =0xFF
Sn_SR =0x00
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x0000
Sn_PORTR =0x0000
Sn_DHAR =0xFFFFFFFFFFFF
Sn_DIPR =0x00000000
Sn_DIP6R =0x00000000000000000000000000000000
Sn_DPORTR =0x0000
Sn_MR2 =0x00
Sn_RTR =0x0000
Sn_RCR =0x00
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0000
Sn_TX_WR =0x0000
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0000
Sn_RX_WR =0x0000
–W6100 Dump Socket 1 Registers–
Sn_MR =0x00
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x00
Sn_IMR =0xFF
Sn_SR =0x00
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x0000
Sn_PORTR =0x0000
Sn_DIPR =0x00000000
Sn_DPORTR =0x0000
Sn_MR2 =0x00
Sn_RTR =0x0000
Sn_RCR =0x00
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0000
Sn_TX_WR =0x0000
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0000
Sn_RX_WR =0x0000
–W6100 Dump Socket 2 Registers–
Sn_MR =0x00
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x00
Sn_IMR =0xFF
Sn_SR =0x00
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x0000
Sn_PORTR =0x0000
Sn_DIPR =0x00000000
Sn_DPORTR =0x0000
Sn_MR2 =0x00
Sn_RTR =0x0000
Sn_RCR =0x00
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0000
Sn_TX_WR =0x0000
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0000
Sn_RX_WR =0x0000
–W6100 Dump Socket 3 Registers–
Sn_MR =0x00
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x00
Sn_IMR =0xFF
Sn_SR =0x00
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x0000
Sn_PORTR =0x0000
Sn_DIPR =0x00000000
Sn_DPORTR =0x0000
Sn_MR2 =0x00
Sn_RTR =0x0000
Sn_RCR =0x00
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0000
Sn_TX_WR =0x0000
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0000
Sn_RX_WR =0x0000
–W6100 Dump Socket 4 Registers–
Sn_MR =0x02
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x04
Sn_IMR =0xFF
Sn_SR =0x22
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x05C0
Sn_PORTR =0x0044
Sn_DIPR =0xFFFFFFFF
Sn_DPORTR =0x0043
Sn_MR2 =0x00
Sn_RTR =0x07D0
Sn_RCR =0x07
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0258
Sn_TX_WR =0x0258
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0458
Sn_RX_WR =0x0458
–W6100 Dump Socket 5 Registers–
Sn_MR =0x00
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x00
Sn_IMR =0xFF
Sn_SR =0x00
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x0000
Sn_PORTR =0x0000
Sn_DIPR =0x00000000
Sn_DPORTR =0x0000
Sn_MR2 =0x00
Sn_RTR =0x0000
Sn_RCR =0x00
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0000
Sn_TX_WR =0x0000
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0000
Sn_RX_WR =0x0000
–W6100 Dump Socket 6 Registers–
Sn_MR =0x00
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x00
Sn_IMR =0xFF
Sn_SR =0x00
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x0000
Sn_PORTR =0x0000
Sn_DIPR =0x00000000
Sn_DPORTR =0x0000
Sn_MR2 =0x00
Sn_RTR =0x0000
Sn_RCR =0x00
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0000
Sn_TX_WR =0x0000
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0000
Sn_RX_WR =0x0000
–W6100 Dump Socket 7 Registers–
Sn_MR =0x00
Sn_PSR =0x00
Sn_CR =0x00
Sn_IR =0x00
Sn_IMR =0xFF
Sn_SR =0x00
Sn_ESR =0x00
Sn_PNR =0x00
Sn_TOSR =0x00
Sn_TTLR =0x80
Sn_FRGR =0x4000
Sn_MSSR =0x0000
Sn_PORTR =0x0000
Sn_DIPR =0x00000000
Sn_DPORTR =0x0000
Sn_MR2 =0x00
Sn_RTR =0x0000
Sn_RCR =0x00
Sn_KPALVTR=0x00
Sn_TX_BSR =0x02
Sn_TX_FSR =0x0800
Sn_TX_RD =0x0000
Sn_TX_WR =0x0000
Sn_RX_BSR =0x02
Sn_RX_RSR =0x0000
Sn_RX_RD =0x0000
Sn_RX_WR =0x0000
Please tell me if there is anything strange.
Thanks,
So what we see here:
You have IP address conflict bit set, but you have only port unreachable interrupt enable bit set.
You have socket 4 interrupt pending. At the same time socket interrupts are not enabled, must not cause hardware interrupt.
Socket4 is in UDP mode, having source port 0x44 and source MAC address 00:00:00:12:00:06, destination port 0x43, and destination MAC address and IP address unresolved. No new data to be sent, all data read.
Source of interrupt for socket4 is clear: something was received on the socket. RD and WR pointers are same means you have read the data, but most probably forgot to clear the interrupt flag. As soon as SENDOK bit is not set, assume you did not send anything onto the socket4 yet (or you cleared the flag).
Now let’s again look at the picture you provided at the beginning.
W6100 asks for IP address, sending from 0.0.0.0 to broadcast ff.ff.ff.ff. Server replies to c0.a8.02.cc, however the response must have been given to ff.ff.ff.ff (broadcast) with W6100 MAC address in the payload. IMHO DHCP server does wrong assuming 192.169.2.204 before DHCP process completes. Maybe because this address has already been leased to the W6100 before.
Then, after accepting DHCP leased IP address, W6100 asks two times if someone has the same IP address.
Shortly another device starts DHCP process, obtains 192.168.2.206, and after completion of DHCP process sends request if anyone else ahs this IP address.
And you say when this packet is received by the W6100, it raises IP address conflict bit.
And you set W6100 to send DHCP decline as soon as this bit gets set.
Right?
You have IPCONF-related interrupt disabled, this means you perform polling of this bit and not (almost immediately) reacting its state change. Are you sure that this IPCONF status bit is being polled regularly and that your W6100 driver notices the change promptly? May be this bit being set earlier than reception of that ARP packet from 12:00:07? Are you sure you see all the packets being transferred on the network in the capture?
by tom3 ·
Thank you for your detailed analysis.
As you posted, I am sending the ARPProbe using a socket-less command.
This is based on the W6100 datasheet section 6.6.1.
After transmission, we poll the IPCONF bit in the IR register in addition to the ARP4 and TOUT bits in the socketless interrupt register SLIR.
The software flow is shown below.
setIRCLR(IR_IPCONF);
setSLRCR(2);// max 3 times
setSLRTR(10000);// timeout=1 second
setSLDIP4R(OfferedIp);
setSLCR(SLCR_ARP4);// send ARP Probe
while(getSLCR()){
osDelay(1);
while(((tmp = getSLIR()) & 0xC0) == 0x00){ // break when ARP4 or TOUT
if((tmp = getIR() & 0x04) == 0x04){
break;// break when IPCONF
osDelay(1);
// check tmp value
// if ARP4 or IPCONF → Detect Conflict, send DHCPDECLINE
// if TOUT → No conflict, continue.
At this timing, there is DHCP broadcast packet communication between 12:00:07 and the DHCP server, but IPCONF was not set.
Then 12:00:07 sends an ARPProbe and the W6100’s IPCONF is set.If the ARPProbe from 12:00:07 does not come, the IPCONF bit will not be set.
According to wireshark, no other packets were flowing during this period.
UDP socket 4 was used for previous DHCP communication (broadcast transmission), and the register value remained. As a test, I closed socket 4 before sending the ARPProbe, and the IPCONF bit was set without any effect.
Thanks,
12:00:07 sends ARP request, not ARP response, therefore 12:00:06 must not react to it. This source does not use this mechanism, thus no explicit proof of using this functionality.
If code breaks in break then you get IPCONF set without receiving the ARP reply and within timeout interval. But note that you assign same
tmpvariable in both locations, and it is important how you checktmp. Assignment syntax differs a little (in while you gettmpassigned to SLIR[7:0], in if - only bit 2 of IR). You may have designed (optimized) this intentionally, but it looks unusual in the debugging environment. Imagine getSLIR() return 0x84 for some reason, would your checks you did not disclose be reliable?Read IR register just before you send ARP, and check its bit 2 to ensure it is reset.
